NISAR and GIS: What India's Newest Earth-Observation Satellite Means for Infrastructure Monitoring
A Geographic Information System (GIS) layers different kinds of location-based data, imagery, sensor readings, survey records, onto a single map so they can be analyzed together. NISAR, the NASA-ISRO Synthetic Aperture Radar satellite, gives GIS a new kind of input: radar imagery that can measure how the ground itself moves, day or night, through cloud cover. For India’s infrastructure planners, that combination turns a space mission into a practical monitoring tool.
Introduction: India’s Newest Eye in the Sky
India now has a satellite built to track exactly this kind of ground movement. NISAR lifted off on 30 July 2025 aboard an ISRO GSLV rocket from the Satish Dhawan Space Centre, carrying radar instruments built jointly by NASA and ISRO. NASA states the satellite can detect the movement of land and ice surfaces down to the centimeter, a level of precision that matters for anything built on ground that shifts: highways, dams, transmission corridors, and urban foundations.
The mission is no longer a launch-day story. It has moved into full science operations, and its data is now reaching Indian users through a dedicated distribution channel.
What Is NISAR and What Makes Its Radar Different?
NISAR is a joint NASA-ISRO Synthetic Aperture Radar mission, the first satellite to carry two radar frequencies, L-band and S-band, on a single platform in a dual-frequency, polarimetric configuration. It flies in a 747-kilometer sun-synchronous orbit with a 12-day repeat cycle, built on ISRO’s I-3K spacecraft bus.
The mission’s defining technology is the SweepSAR technique, which uses a 12-meter unfurlable antenna to image a wide swath of roughly 240 kilometers in a single pass, far wider than earlier radar satellites managed while still holding high resolution. Unlike an optical satellite, synthetic aperture radar builds its images from reflected radio signals rather than reflected sunlight, which is what lets NISAR work through cloud cover and darkness alike.
NASA delivered the L-band SAR payload, a high-precision GPS system, and the 12-meter unfurlable antenna, while ISRO delivered the S-band SAR payload, the spacecraft bus, and the launch itself.
India’s Role in NISAR: ISRO, NASA, and the Cost of a Joint Mission
India’s financial commitment to NISAR is a matter of public record. In a written reply to the Rajya Sabha in March 2023, the government stated that ISRO’s own expenditure on the satellite stood at Rs 469.40 crore as of February 2023, excluding launch cost. That figure covers ISRO’s share of the build alone, not the mission’s total cost, since NASA funded and built the L-band payload separately.
ISRO’s contribution went beyond funding. The spacecraft bus, the S-band radar, and the GSLV launch vehicle that carried NISAR to orbit were all India’s responsibility, alongside the ground infrastructure needed to receive and process the satellite’s S-band data once it started transmitting.
How Synthetic Aperture Radar Sees What Optical Satellites Cannot
Synthetic aperture radar works by sending out radio pulses and measuring how they bounce back, a signal called radar backscatter that changes with the roughness, moisture, and structure of whatever it hits. Because it generates its own signal instead of relying on sunlight, SAR keeps collecting data through cloud cover and at night, conditions that limit what optical Earth-observation satellites can capture, particularly during India’s monsoon months. NISAR’s two radar bands are not interchangeable. Each is tuned to different physical phenomena, and the mission was designed around that split rather than treating one as a backup for the other.
Aspect L-band SAR (NASA) S-band SAR (ISRO)
Best suited to Soil moisture, forest biomass, land and ice motion Agriculture, grassland ecosystems, infrastructure movement
Delivered by NASA ISRO
India access channel Alaska Satellite Facility Distributed Active Archive Center Bhoonidhi
Both bands can contribute to surface-motion analysis. In NASA’s own account of the mission at launch, S-band is the frequency described as excelling at monitoring infrastructure movement, distinct from L-band’s focus on soil moisture, forest biomass, and land or ice motion.
From Signal to Data: How NISAR Reaches Indian Users Through Bhoonidhi
NISAR’s two radar bands reach users through two separate channels, and keeping them straight matters for anyone planning to work with the data. ISRO distributes S-band products through Bhoonidhi, its Earth observation data dissemination hub, while NASA’s L-band products are released through the Alaska Satellite Facility Distributed Active Archive Center, a separate system entirely.
Bhoonidhi’s S-band release has followed a defined schedule rather than an open-ended trickle. Starting with Cycle 25, which began on 8 July 2026, ISRO has systematically generated and released S-band SAR products from its operational production environment, currently under Product Baseline version v1.4.0. The catalog includes standard products such as L1-RSLC, L2-GSLC, and L2-GCOV, interferometric products including L1-RIFG, L1-RUNW, and L2-GUNW, and offset products for tracking surface displacement.
Calibration Backbone
ISRO performs calibration and validation for these products using the PAN India Corner Reflector network alongside homogeneous distributed targets and selected science targets, together establishing the radiometric, geometric, and polarimetric consistency the data needs. The Corner Reflector network is unglamorous infrastructure, but it is a core part of what gives the radar measurements arriving through Bhoonidhi the precision that ground-deformation monitoring needs.
What GIS Can Do With NISAR Data for Infrastructure Monitoring
Raw SAR data is not immediately usable on its own. It needs geometric and radiometric correction, terrain adjustment, and conversion into formats a GIS platform can layer against roads, pipelines, and property boundaries. This is where GIS raster analysis tools come in, turning a radar scene into something an infrastructure team can actually layer against a map.
Radar Raster Processing
ArcGIS Pro, together with the ArcGIS Image Analyst extension, provides the raster tools SAR analysis generally depends on, including terrain correction and radiometric calibration to make backscatter values comparable across scenes and time periods. Esri’s published ground-displacement workflow in ArcGIS Pro is currently documented for Sentinel-1 SLC data specifically, so applying the same class of raster analysis to NISAR’s products is a matter of general SAR capability rather than a documented, ready-made NISAR pipeline.
Once processed, radar imagery can still sit alongside standard vector layers such as road centerlines or utility corridors, giving an analyst a way to compare conditions at a specific stretch of highway or transmission tower foundation across two acquisition dates.
Interferometric Analysis
Interferometry, comparing two SAR images of the same location taken at different times, can surface ground deformation patterns invisible to the eye and to optical satellites alike. NISAR’s interferometric product types, including its unwrapped interferogram files, already carry a share of this processing from ISRO and NASA before they reach a user, though the exact processing required still depends on the specific product and the analyst’s own workflow.
ArcGIS Pro’s raster and imagery tools, paired with ArcGIS Image Analyst for more advanced radar analysis, are what analysts use to work with, visualize, and compare these outputs against other spatial data.
Regional Context Layers
The Indo ArcGIS Living Atlas supplies ready-to-use Indian base layers, from administrative boundaries to land cover, that give radar-derived deformation data geographic context without requiring every analyst to build reference layers from scratch.
Infrastructure agencies working on road networks, power transmission, and urban planning increasingly need this kind of monitoring capability as part of their broader move toward digital, location-based operations. Solutions built on ArcGIS for National Government and State and Local Government already support this shift toward proactive, spatially aware asset management.
How Indian Agencies and Researchers Are Approaching NISAR Data Today
NISAR’s S-band SAR data has been available through Bhoonidhi on a systematic release schedule since Cycle 25 began in July 2026, published under Product Baseline v1.4.0. That gives Indian researchers, technical agencies, and infrastructure teams direct, ongoing access to a growing S-band archive, in place of the more limited, earlier-stage releases that preceded it. Using this archive today means keeping ISRO’s own caveats in mind, covered in the Challenges section below, and fitting radar analysis into GIS workflows that have mostly been built around optical imagery so far.
Challenges and the Road Ahead
Processing Skill Remains Scarce
The specialized skill needed to turn raw radar scenes into terrain-corrected, GIS-ready layers is concentrated in a small pool of trained analysts. Closing that gap depends less on the data itself than on how quickly infrastructure teams invest in training analysts alongside adopting the software.
Mission-Scale Data Volumes Add Infrastructure Load
NASA’s own NISAR mission materials put the satellite’s combined L-band and S-band data output at roughly 80 terabytes a day, or about 100 petabytes over its three-year prime mission. NASA does not break that figure out by band, but even a fraction of it arriving as S-band products means building the storage and processing capacity to handle data at this scale is a distinct investment from the GIS analysis software itself.
Calibration Is Still Maturing
ISRO’s own release notes for the current S-band products acknowledge residual radiometric banding in low signal-to-noise regions such as oceans and deserts, and note that radio-frequency interference mitigation has been applied but may still leave artifacts in some scenes. Teams working with today’s S-band products should expect data quality to keep improving release over release, rather than treating the current baseline as final.
The Historical Archive Is Still Filling In
S-band products only began releasing systematically from Cycle 25 in July 2026, and ISRO is reprocessing earlier acquisitions in phases rather than all at once. Time-series deformation analysis depends on comparing many dates, so analysts working with NISAR today are still building toward the baseline they will eventually have.
Radar Data Has Real Limits
NISAR can show that the ground or a structure has moved. On its own, it can’t explain why the ground moved, say whether a structure is unsafe, or replace an engineer checking the site in person. Treating that signal as a final answer, instead of a reason to look closer, means acting on only part of the picture.
FAQs
1.What is the NISAR satellite and who built it?
NISAR is the NASA-ISRO Synthetic Aperture Radar satellite, a joint mission that launched on 30 July 2025. NASA built the L-band radar payload and ISRO built the S-band radar payload, spacecraft bus, and launch vehicle.
2.How is NISAR different from other Earth observation satellites?
NISAR carries two radar frequencies on one satellite and uses SweepSAR technology to image a roughly 240-kilometer-wide swath in a single pass. Because it uses radar rather than sunlight, it collects data through cloud cover and at night, conditions that limit optical satellites.
3.How can GIS be used to analyse NISAR radar data?
ArcGIS Pro, often paired with the ArcGIS Image Analyst extension for advanced radar workflows, can process and visualize NISAR’s SAR products and layer them against roads, utilities, and other infrastructure. Since NISAR’s own interferometric products already carry a significant share of ground-deformation processing from ISRO and NASA, GIS tools are mainly used to analyze and compare those outputs across dates rather than generate deformation results from scratch.
4.Where can Indian users access NISAR data?
S-band SAR products are available through Bhoonidhi, ISRO’s Earth observation data hub, with systematic releases underway since Cycle 25 began in July 2026. L-band data comes from a separate NASA channel, the Alaska Satellite Facility Distributed Active Archive Center.
5.What are the main challenges in applying NISAR data to infrastructure monitoring?
Processing national-scale SAR data requires specialized skills that remain scarce, and the historical archive is still incomplete as ISRO reprocesses earlier acquisitions in phases. While radar data can flag that ground or structures have moved, confirming the cause or safety implications still requires on-site inspection.
Written by
Esri India Marketing
Next Article
Smarter Asset Inspection with ArcGIS API for Python
Read this article
