How Hyperspectral Imagery Is Unlocking New Possibilities for Indian Mining and Geology
Hyperspectral imagery for mining India refers to the use of airborne or satellite sensors that capture hundreds of contiguous spectral bands across the electromagnetic spectrum to identify and map minerals at the surface and subsurface level, giving geologists and mining operators the ability to detect ore bodies, alteration zones, and environmental impacts with unprecedented precision.
India’s Mineral Hunt Goes Deeper Into the Spectrum
India sits on one of the world’s most mineral-rich landmasses, yet a significant portion of its subsurface resources remains unmapped or underexplored. The Geological Survey of India (GSI) estimates that only about 10% of India’s prospective mineral belt has undergone systematic scientific exploration. Conventional satellite imagery and even multispectral sensors often can’t distinguish between minerals that look identical in colour but carry completely different economic value.
That’s where hyperspectral remote sensing changes everything. When the Indian Space Research Organisation (ISRO) partnered with NASA’s Jet Propulsion Laboratory to fly the Airborne Visible Infrared Imaging Spectrometer-Next Generation (AVIRIS-NG) over India in 2016 and 2018, the results were striking. Survey flights over the Aravalli Fold Belt in Rajasthan, the Gadag Schist Belt in Karnataka, Sittampundi in Tamil Nadu, and Chhatarpur district in Madhya Pradesh produced mineral maps that conventional surveying would have taken years to generate. India’s Critical Minerals Mission now depends, in part, on exactly this kind of spectral intelligence.
What Is Hyperspectral Imagery?
Hyperspectral imagery is a remote sensing technique in which a sensor captures reflected light across hundreds of narrow, contiguous spectral bands, typically spanning 380 to 2510 nanometres, allowing analysts to construct a unique spectral signature for each pixel and match it against a reference library to identify specific minerals, rock types, or surface materials.
Standard cameras capture three bands: red, green, and blue. Multispectral sensors capture 4 to 15 bands. Hyperspectral sensors like AVIRIS-NG capture up to 425 spectral bands at 5 nm resolution, which means each pixel in the image carries enough detail to function almost like a laboratory spectrometer reading.
That granularity is the key differentiator. Minerals such as kaolinite, montmorillonite, muscovite, and chlorite all look similar in a standard colour photograph, but each has a distinct absorption feature in the short-wave infrared (SWIR) range between 2000 and 2500 nm. Hyperspectral imagery resolves these differences with enough precision to map hydrothermal alteration zones, identify lithium-bearing pegmatites, and flag acid mine drainage before it becomes a visible surface problem.
Hyperspectral vs Multispectral: Why the Difference Matters in Geology
The distinction is not merely technical. It has direct exploration economics attached to it.
Multispectral sensors capture 4 to 15 broad spectral bands, each spanning 70 to 400 nanometres. They are effective for land cover classification and broad lithological mapping, but they cannot resolve the fine absorption features that separate one mineral from another. Hyperspectral sensors capture 100 to 425 narrow contiguous bands at 5 to 10 nm widths, giving each pixel a detailed spectral fingerprint rather than a colour average.
In practice, a multispectral sensor can tell you that a pixel contains iron-bearing material. A hyperspectral sensor tells you whether that material is goethite, hematite, or jarosite, each of which carries a different implication for ore grade, acid mine drainage risk, and metallurgical processing requirements. For exploration teams targeting lithium, rare earth elements (REE), or chromite in India’s diverse mineral belts, that level of discrimination is not optional. It is the difference between drilling in the right place and drilling at all.
India’s Hyperspectral Capabilities: From AVIRIS-NG to PRISMA and HySIS
India has built a credible hyperspectral portfolio over the past decade, progressing from borrowed airborne platforms to sovereign satellite assets.
AVIRIS-NG (ISRO–NASA) was deployed across India in two campaign phases in 2016 and 2018, covering more than 60 sites across major mineral belts. The data has since driven peer-reviewed research on bauxite prospecting in Chhatarpur (MP), gold mineralisation indicators in the Gadag Schist Belt, and anorthosite mapping at Sittampundi. ISRO makes processed AVIRIS-NG data available through NRSC’s Bhuvan portal, opening access for GSI, IBM, MECL, and state mining directorates.
HySIS (Hyperspectral Imaging Satellite), launched by ISRO in 2018, is India’s first domestic hyperspectral satellite. It operates in VNIR (visible and near-infrared) and SWIR ranges and has been used for mineral mapping across the Eastern Ghats and parts of the Deccan Trap.
PRISMA (from the Italian Space Agency, ASI) and EnMAP (German Space Agency) have both captured data over Indian mineral belts at commercial or research-access tiers. These sensors, with repeat-pass capability, allow prospectivity sweeps over large areas like the Singhbhum Shear Zone (Jharkhand) or the Bhilwara belt (Rajasthan) that would be cost-prohibitive to cover with airborne surveys. ISRO’s upcoming EOS-08 satellite also carries multispectral and hyperspectral payloads, indicating that sovereign spectral data coverage will only deepen in the coming years.
How Hyperspectral Imagery Powers Mineral Exploration
The value of hyperspectral data is unlocked through a stack of spectral analysis techniques, many of which are now operationalised within ArcGIS Pro and ArcGIS Image.
Minimum Noise Fraction (MNF) transformation is the standard first step. It separates signal from noise in the hyperspectral data cube, reducing dimensionality without losing the spectral detail needed for mineral discrimination. ArcGIS Image Analyst supports this workflow natively, allowing geoscientists to run MNF, visualise endmembers, and move directly into classification within the same platform.
Spectral Angle Mapper (SAM) compares each pixel’s spectral vector against a reference library, the USGS spectral library or the JPL ECOSTRESS library, to determine the angular distance between an unknown spectrum and a known mineral. A small angle means a close match. SAM is robust to illumination variation and is widely used for mapping hydrothermal alteration halos around prospective ore bodies.
Adaptive Coherence Estimator (ACE) and Constrained Energy Minimization (CEM) take detection further by performing sub-pixel target identification, surfacing minerals that may occupy only a fraction of a 5-metre pixel. This is particularly relevant for disseminated REE mineralisation or thin pegmatite veins that fall below spatial resolution thresholds.
Linear Spectral Unmixing (LSU) decomposes each pixel into fractional abundances of multiple minerals, generating proportion maps rather than hard classifications. This is the preferred approach for mixed lithologies common in India’s Precambrian shield terrains.
For teams moving toward GeoAI workflows, the deep learning toolbox in ArcGIS Pro integrates directly with ArcGIS Image Analyst to run 1D convolutional neural networks (CNNs) and transformer-based classifiers on hyperspectral cubes. These models consistently outperform classical SAM and Matched Filter techniques on sub-pixel mineral identification tasks, especially when training data from field spectroradiometry (ASD FieldSpec) is available for fine-tuning.
Applications Across India’s Mineral Belts
India’s mineral endowment spans diverse geological terrains, and hyperspectral imagery has demonstrated distinct value across all of them.
Aravalli Fold Belt, Rajasthan is one of India’s most intensively studied hyperspectral targets. AVIRIS-NG flights over Jahajpur identified kyanite, sillimanite, and graphite-bearing zones with spatial precision impossible to achieve from conventional geological mapping. The Bhilwara belt within the same province is a target for lithium-bearing pegmatites, where hyperspectral SWIR data can discriminate lepidolite and spodumene spectral signatures from host granites.
Dharwar Craton, Karnataka hosts the Gadag Schist Belt, site of gold mineralisation associated with quartz veins and hydrothermal alteration. Research published via InTech Open demonstrated that SAM, ACE, and CEM applied to AVIRIS-NG data over Gadag detected muscovite and chlorite alteration halos, classic pathfinder signatures for greenstone belt gold mineralisation.
Singhbhum Shear Zone, Jharkhand is one of the world’s significant copper-uranium belts. Hydrothermal alteration mapping using SWIR data here can discriminate chlorite-epidote from sericite-pyrite assemblages, which have different implications for copper grade and uranium association.
Chhatarpur District, Madhya Pradesh was the site of a 2025 AVIRIS-NG study on bauxite prospecting, published in the Arabian Journal of Geosciences. Gibbsite and boehmite spectral signatures were mapped across lateritic plateaus, providing MECL with a drill-target shortlist derived entirely from airborne spectral data rather than ground survey.
Critical Minerals Mission angle: India’s Ministry of Mines has identified 30 critical minerals, including lithium, cobalt, nickel, and REEs, as strategic priorities. Hyperspectral imagery is arguably the only remote sensing technique capable of discriminating against lithium-bearing mineral assemblages, REE-bearing carbonatites, and battery metal host rocks at a reconnaissance scale. For GSI teams tasked with accelerating critical mineral discoveries under the National Mineral Exploration Trust (NMET) framework, AVIRIS-NG and PRISMA data represent a force multiplier that reduces the field survey burden substantially.
Beyond Exploration: Mining Operations, Safety, and Reclamation
Hyperspectral technology’s value does not end at ore discovery. Across the mining lifecycle, it addresses operational and environmental challenges that conventional sensors cannot resolve.
Drone-borne hyperspectral for active mines is one of the fastest-growing applications in Indian mining. Drone-mounted hyperspectral sensors can fly over run-of-mine stockpiles, capturing mineral grade variability at spatial resolutions below 10 centimetres. This enables blending control, the process of mixing ore from different stockpiles to meet processing plant feed specifications, without the delays of laboratory assaying. Site Scan for ArcGIS integrates drone-captured imagery, including hyperspectral payloads, into an enterprise geospatial workflow, enabling mine operators to process, analyse, and share drone data across ArcGIS Enterprise with no GIS specialisation required in the field.
Acid mine drainage (AMD) detection is a critical environmental application, particularly relevant to India’s coal-bearing regions in Jharkhand, Odisha, and Chhattisgarh. AMD is characterised by the presence of iron sulphate minerals including jarosite, schwertmannite, and ferrihydrite, each with distinct SWIR absorption features that hyperspectral sensors resolve clearly. Early spectral detection allows mine operators to contain AMD before it reaches watercourses, directly supporting Star Rating of Mines compliance under the Ministry of Mines framework.
Mine reclamation and vegetation stress monitoring close the loop on the mining lifecycle. Post-closure, hyperspectral sensors detect subtle changes in vegetation reflectance caused by soil contamination or tailings leachate. Chlorophyll absorption in the red-edge region (around 700 nm) is suppressed under heavy metal stress, providing an early warning of revegetation failure that visible inspection would miss entirely. ArcGIS Spatial Analyst supports change detection and vegetation index mapping workflows that convert this spectral data into actionable reclamation dashboards.
Adani Natural Resources, a large-scale coal and mineral mining company operating multiple sites across India, has demonstrated how an enterprise geospatial approach transforms mining operations. Working with Esri India, Adani deployed ArcGIS Enterprise to integrate drone data, geological reports, mining plans, and environmental monitoring parameters into a single spatial platform. Monthly drone captures are hosted through ArcGIS Image Server, enabling continuous change detection across mine landscapes, tracking land reclamation, vegetation health, and DGMS-mandated slope safety parameters in near-real time. The platform has helped Adani manage complexities of multiple concurrent mining sites with datasets across coordinate systems and formats, a challenge directly analogous to what hyperspectral image management demands at scale.
Aligning with India’s Mining Policy Frameworks
Several active Indian policy frameworks create direct demand for hyperspectral-grade geospatial intelligence.
National Mineral Exploration Policy (NMEP), 2016 mandates systematic airborne geophysical and remote sensing surveys over all prospective mineral belts. Hyperspectral data, particularly from NRSC’s AVIRIS-NG archive, directly supports the mineral atlas outputs this policy calls for.
NMET (National Mineral Exploration Trust) funds mineral exploration by junior explorers and research institutions, with geospatial data outputs as a deliverable. Hyperspectral mineral maps produced in ArcGIS and shared through Indo ArcGIS Living Atlas can form part of these public-access data products.
Critical Minerals Mission (launched 2023) has tasked GSI, MECL, and NMET with accelerating discovery of 30 strategic minerals. Hyperspectral imagery is the fastest reconnaissance tool available for this mandate, enabling national-scale spectral prospectivity mapping in months rather than decades of ground survey.
Star Rating of Mines (Ministry of Mines) evaluates operating mines on environmental compliance, reclamation progress, and safety standards. Drone hyperspectral monitoring of vegetation stress, AMD spread, and slope stability feeds directly into the evidence base for higher Star ratings.
GeoAI and the Next Frontier in Spectral Analysis
The move from classical spectral techniques to deep learning-based mineral mapping is already underway in research environments and is beginning to enter operational GSI and IBM workflows.
1D CNNs applied to spectral vectors outperform SAM on mixed-mineral pixels by learning non-linear spectral features that angle-based matching cannot resolve. 2D CNNs incorporate spatial context, improving discrimination at mineral belt boundaries where gradational transitions occur. Transformer-based models are showing early promise for few-shot mineral classification, relevant where training labels from field spectroradiometry are sparse.
Within the ArcGIS ecosystem, the deep learning toolbox in ArcGIS Pro allows exploration teams to train, validate, and deploy these classifiers directly on hyperspectral rasters without migrating to a separate machine learning environment. ArcGIS GeoAnalytics enables large-scale distributed processing of hyperspectral archives, critical when working with AVIRIS-NG data cubes that can exceed several gigabytes per flight line.
The Indo ArcGIS Living Atlas provides curated India-specific basemaps, geological boundary layers, and administrative frameworks that anchor hyperspectral-derived mineral maps in their correct spatial and policy context, enabling GSI outputs to be consumed directly by state mining departments and district-level decision makers.
Challenges and the Road Ahead
Hyperspectral imagery for Indian mining has not yet reached the stage of routine operational deployment. Several barriers still stand between its demonstrated research value and widespread industry adoption.
Challenge Current State Path Forward
Data access and archival fragmentation AVIRIS-NG data is distributed across ISRO, NRSC, and research institutions, with no single operational portal for commercial users. The Ministry of Mines’ proposed National Geoscience Data Repository, if implemented with spectral data integration, could centralise access materially.
Processing skill gaps Classical SAM and MNF workflows require spectral remote sensing expertise not yet mainstream in Indian mining companies. Integration of these tools into ArcGIS Image Analyst and ArcGIS Pro lowers the entry barrier, enabling geoscientists to run spectral analysis without separate remote sensing software licences.
Atmospheric correction at scale AVIRIS-NG and PRISMA data require rigorous radiometric and atmospheric correction before spectral matching is reliable. Standardised correction protocols at NRSC have improved pre-processed data quality, though users working with raw PRISMA or EnMAP data must still account for correction accuracy independently.
Satellite revisit vs airborne resolution trade-off PRISMA and HySIS offer wide-area repeat coverage but at 30-metre resolution, which misses narrow pegmatite veins and thin shear zones. AVIRIS-NG offers 4-metre resolution but covers limited areas per campaign. The optimal Indian exploration workflow combines PRISMA for reconnaissance-scale prospectivity screening with targeted AVIRIS-NG or drone hyperspectral surveys for drill-target definition.
The trajectory is clear: as satellite hyperspectral resolution improves, as deep learning reduces the interpretation burden, and as ArcGIS-native workflows democratise access to spectral analysis, hyperspectral imagery will shift from a research speciality to a standard tool in every Indian exploration company’s geospatial stack.
Esri India supports mining and natural resource organisations across India with geospatial technology that spans exploration, operations, environmental compliance, and mine closure. Explore the Mining and Natural Resources  to see how ArcGIS is deployed across the full mining lifecycle.
FAQs
1.What is hyperspectral imagery?
Hyperspectral imagery captures reflected light across hundreds of narrow spectral bands, typically from 380 to 2510 nanometres, generating a unique spectral fingerprint per pixel that identifies specific minerals, soil types, or vegetation conditions invisible to conventional sensors.
2.How is hyperspectral imagery used in mineral exploration?
It maps hydrothermal alteration zones and identifies ore-associated mineral assemblages like sericite, chlorite, and kaolinite, generating drill-target maps far faster than ground surveys. Spectral techniques such as SAM and ACE compare each pixel against reference mineral libraries to flag prospective zones with high accuracy.
3.What is AVIRIS-NG, and where has it been used in India?
AVIRIS-NG is an airborne hyperspectral sensor jointly operated by ISRO and NASA’s JPL, capturing 425 spectral bands at 5 nm resolution. Flown over India in 2016 and 2018, it has mapped targets in Rajasthan, Karnataka, Tamil Nadu, and Madhya Pradesh for gold, bauxite, and anorthosite mineralisation.
4.How does hyperspectral differ from multispectral imagery?
Multispectral sensors capture 4 to 15 broad bands, enabling general land cover and lithological classification. Hyperspectral sensors capture 100 to 425 narrow bands, enabling species-level mineral identification that multispectral data simply cannot achieve.
5.Which Indian agencies use hyperspectral imagery for mining?
GSI, MECL, NMET, IBM, ISRO, and NRSC are the primary agencies involved in hyperspectral data acquisition and mineral mapping. ISRO and NRSC lead data acquisition through AVIRIS-NG campaigns and the HySIS satellite, while GSI and MECL use processed outputs for geological surveys and drill-target generation.
Written by
Esri India Marketing
Next Article
GIS for Irrigation: How India Is Designing Smarter Pipeline Network
Read this article
