GIS for Flash Flood Early Warning: How India Is Preparing for Cloudbursts
Geographic Information System (GIS) for flash flood early warning uses maps of land, rivers, rainfall, and settlements to show where heavy rain can quickly turn into a dangerous flood, and who needs to be warned first. In India’s hill states, where Jammu and Kashmir alone recorded at least 35 cloudbursts by early August 2026, these maps help officials act in the short time between a downpour and a flood.
Introduction: Why Cloudbursts Are India’s Hardest Flash Flood Warning Problem
The Ministry of Earth Sciences (MoES) describes a cloudburst as very heavy rainfall of about 100 mm in an hour over an area of about 20 to 30 sq km. In 2023, MoES told Parliament that cloudbursts cannot be predicted anywhere in the world, because they are small, short-lived, and develop suddenly. Most happen in remote hills and go unrecorded, which is why India does not yet have a map of cloudburst-prone areas. Cloudbursts are now a regular part of the monsoon in the hills.
Himachal Pradesh recorded 46 cloudbursts and 98 flash floods during the 2025 monsoon, according to the State Emergency Operations Centre, as reported by All India Radio. Since no one can say exactly where the next cloudburst will hit, the focus is on what can be known in advance: where the water will go once it falls, and who lives in its path.
What Is GIS for Flash Flood Early Warning?
GIS for flash flood early warning means using maps and location data to find the places where heavy rain can quickly become a dangerous flood, and then linking those places to warnings. It brings the height of the land, rivers, soil, land cover, past floods, and live rainfall together on one map. Instead of guessing where a cloudburst will strike, it shows which valleys, villages, and roads would flood fastest if one did. Everything starts with a height map of the land, called a digital elevation model (DEM).
Water generally flows downhill, so a DEM helps show where rainwater is likely to move and collect, and how quickly a small stream can swell. ArcGIS Pro can carry out this analysis using the hydrology tools in ArcGIS Spatial Analyst. Teams also have ready data to start with. Indo ArcGIS Living Atlas includes a 30 m India DEM, river lines for 27,575 rivers from India-WRIS, and the India Flood Inventory, a record of floods across India from 1967 to 2023 developed by IIT Delhi’s HydroSense Lab with the India Meteorological Department (IMD).
India’s Warning Chain: IMD Radars, the Flash Flood Guidance System, and SACHET
Early warnings begin with observing the atmosphere and rainfall. In December 2025, MoES said Doppler Weather Radars had been installed at ten locations in the western Himalayan states, from Srinagar and Leh to Kufri, Mukteshwar, and Lansdowne, sending fresh readings every ten minutes. Uttarakhand has three of these radars, along with 31 automatic weather stations, 20 automatic rain gauges, 71 district rainfall stations, and a high-altitude weather system at the Kedarnath helipad, according to an April 2026 reply in Parliament. MoES has also announced phased-array radars for Jammu and Kashmir, Uttarakhand, and Himachal Pradesh.
IMD turns these readings into guidance. Since 2020, its Flash Flood Guidance System has issued a daily bulletin that shows flash flood risk for each small river catchment 6 to 24 hours ahead, in 4 km by 4 km blocks, for India, Nepal, Bhutan, Bangladesh, and Sri Lanka. The Central Water Commission (CWC) and other users receive it every six hours. GIS plays an important role in how IMD shows and shares its warnings. Its Multi-Hazard Early Warning Decision Support System (MHEW-DSS), launched in January 2024, uses GIS maps to give location-specific forecasts for more than 1.5 lakh pin codes, 5,700 blocks, and over 6.2 lakh villages.
According to a PIB release from April 2026, IMD’s impact-based warnings now reach nearly 80 percent of the population across India and neighbouring regions. Warnings reach the public through SACHET, the alert system run by the National Disaster Management Authority (NDMA). By April 2026, SACHET had been used to send over 134 billion SMS alerts in more than 19 Indian languages. In May 2026, India launched a Cell Broadcast System, linked to SACHET, which sends alerts to phones within seconds and is already in use for the Char Dham Yatra.
From Terrain to Risk Map: How GIS Shows Where a Cloudburst Becomes a Flash Flood
Mapping the Danger Zone
MoES says cloudbursts are most common between 1,000 and 2,500 m along the southern edge of the Himalaya, in the hills of the Northeast, and on the western side of the Western Ghats. A DEM can mark out this height band, and adding villages, roads, and bridges on top shows where people live inside it.
Following the Water
In ArcGIS Pro, the Fill tool first fixes small gaps and errors in the DEM. Flow Direction then shows which way water runs from every point on a slope, and Flow Accumulation shows where it collects. Watershed and Stream Order outline the small valleys and streams that feed each river, which is where flash floods begin.
Scoring the Risk
Researchers combine slope, height, land cover, soil, and past flood sites to give each area a risk score. A 2023 study in the journal Natural Hazards used 122 past flash flood sites in Uttarakhand and found that combining statistical methods with a neural network produced the most accurate risk map. In the Esri India Young Scholar Program 2026, Sreya Bhattacharyya of Birla Institute of Technology, Mesra, was a runner-up with a project on cloudburst probability assessment using atmospheric data and machine learning in ArcGIS Pro.
Adding People and Property
A risk map becomes useful when it shows what stands in the way of the water. Placing villages, highways, bridges, pilgrimage routes, and campsites on the map shows which places would be hit first, so officials can plan road closures and safe shelters before the monsoon.
Checking After Every Flood
Radar satellites can see through monsoon clouds. A research paper published in ArcIndia News used Sentinel-1 radar images and the radar tools in ArcGIS Pro to map Delhi’s July 2023 floods, which covered about 366 sq km at their peak on 16 July. With ArcGIS Image Server and AI capabilities within ArcGIS, teams can map flooded areas after each event and use them to update risk maps for the next monsoon. State disaster management and water resources teams can explore Emergency Management solutions on ArcGIS to plan for flash floods.
How Indian Agencies Use Esri Technology for Rainfall and Hazard Monitoring
IMD’s Hydrology Division has worked with Esri India for about 15 years. In an ArcIndia News interview, Rahul Saxena, Head of the Hydrology Division, said the division uses both enterprise and desktop versions of Esri’s tools, and that Esri India has developed many applications for IMD, including its customized Rainfall Information System.
He also said GIS has made weather forecasting more location and time-specific, helping meteorologists identify areas at higher risk of extreme weather so warnings can be targeted. Bihar shows how close rainfall monitoring can get. Dr. CN Prabhu, Joint Director (Technical) at Bihar Mausam Seva Kendra, said in ArcIndia News that the state has a rain gauge every 3 sq km and a weather station every 150 sq km, with data collected every 15 minutes.
The agency uses Esri’s ArcGIS along with other tools, and he described this rainfall data as the basis for managing the flood situation in Bihar. In Karnataka, the Karnataka State Natural Disaster Monitoring Centre (KSNDMC) set up ArcSDE, ArcGIS Desktop, ArcGIS Server, and web GIS tools for a network of more than 6,000 automatic rain gauges and more than 750 weather stations, all reporting every 15 minutes. According to the Esri India case study, reports that once took 7.5 to 20 hours of staff time were ready in under 30 minutes. The system could also send “high intensity rainfall” alerts to users straight away.
“The use of technology developed by the Esri India team has been immensely helpful in efficiently handling ever growing data sets, checking errors in the reports/maps owing to manual interference and increasing the pace of data processing, report generation, and information dissemination.”
Dr. G.S. Srinivasa Reddy, Director, KSNDMC At the national level, India-WRIS brings water data from more than 50 agencies into one place. CWC and the National Remote Sensing Centre first built it on ArcGIS in 2008, and a revamped version was launched in July 2019, with Esri India supporting the National Water Informatics Centre. It holds more than 130 layers, with modules for rainfall, reservoir and river levels, and floods from extreme events.
From Risk Map to Alert: Linking Rainfall, Exposure, and Warning Dissemination
A risk map works best when it is linked to a clear trigger. The Flash Flood Guidance System already reports risk for each small river catchment, and a risk map can use the same catchments. When a bulletin flags a catchment, officials can see which high-risk villages, roads, and bridges lie inside it. Rain gauges can make alerts faster still. ArcGIS Velocity can read live sensor data and send an alert when rainfall in a catchment crosses a set limit.
ArcGIS Dashboards can then show district officials, on one screen, which areas are under alert, which roads are closed, and where rescue teams are. Teams can also start from a ready-made option. The Disaster Management solution in Indo ArcGIS, developed by Esri India, offers automated alerts and live feeds for active hazards, and helps estimate the population and area affected.
Field staff complete the picture. With ArcGIS Survey123 forms, they can report water levels, blocked roads, debris, and damage with photos and exact locations, so the next risk map reflects what happened on the ground. The winning project in the Esri India Young Scholar Program 2026, “Smart FloodGuard” by Swapnali Magadum of Shivaji University, Kolhapur, presented a mobile and IoT-based (Internet of Things) system for real-time flash flood monitoring, early warning, and evacuation. Reaching people is the final step. Cell Broadcast can help send alerts to phones within a defined area, giving authorities another channel to reach people in high-risk locations.
Challenges and the Road Ahead
Radar Blind Spots in Deep Valleys
Radar beams travel in straight lines, so high ridges can block them and leave parts of deep Himalayan valleys poorly covered. This matters most for cloudbursts, which form over small areas and can be missed between radar sites. In November 2025, MoES announced plans for phased-array radars in Jammu and Kashmir, Uttarakhand, and Himachal Pradesh to improve coverage of this difficult terrain.
Few Rain Gauges at High Altitude
Rain gauges and weather stations thin out higher up the mountains, and many cloudbursts occur between 1,000 and 2,500 m. Fewer gauges mean fewer live alerts, and less past rainfall data to build and test risk maps. In October 2025, Himachal Pradesh asked the Centre for more radars and automatic weather stations so that every district, especially the disaster-prone areas, is better covered.
Minutes, Not Hours
In small, steep valleys, a flood can arrive very soon after the heaviest rain, often faster than a regional bulletin can be updated. This leaves little time to analyze an event and decide who to warn. Warnings need to be planned in advance, using risk maps to mark the most exposed places and rainfall limits to trigger alerts automatically, so action can start the moment those limits are crossed.
Glacial Lakes as a Second Threat
Floods in the Himalaya do not always start with rain, as a burst glacial lake can send water down the same valleys a cloudburst would. NDMA has identified 195 potentially high-risk glacial lakes across six Himalayan states and union territories, and is running a ₹150 crore program to reduce the risk of glacial lake outburst floods in four of them. Under this effort, weather stations now monitor two lakes in Sikkim and a pilot early warning system has been installed in Lahaul and Spiti, Himachal Pradesh.
Cloudbursts remain hard to predict, but the floods that follow move along the shape of the land, and that can be mapped before the monsoon arrives. Together with wider radar coverage, location-specific warnings, and faster alert channels, these maps can help authorities make better use of the limited warning time available during flash flood events.
FAQs
1.What is a cloudburst, and can it be predicted?
MoES describes a cloudburst as very heavy rainfall of about 100 mm in an hour over an area of about 20 to 30 sq km. It has said cloudbursts cannot be predicted anywhere in the world, because they are small, short-lived, and develop suddenly. Forecasters instead warn about heavy rain and flash flood risk across wider areas.
2.How does GIS help in flash flood early warning?
GIS uses height maps, rivers, and land cover to show where rainwater will collect and which valleys would flood fastest. It then links these danger zones to villages, roads, and bridges, so warnings can be targeted to the people most at risk.
3.What is the Flash Flood Guidance System in India?
The Flash Flood Guidance System is run by IMD and has issued a daily bulletin since 2020. It shows the risk of flash floods for small river catchments 6 to 24 hours ahead, for India, Nepal, Bhutan, Bangladesh, and Sri Lanka.
4.Which ArcGIS tools are used for flash flood susceptibility mapping?
ArcGIS Pro, with ArcGIS Spatial Analyst, has hydrology tools such as Fill, Flow Direction, Flow Accumulation, Watershed, and Stream Order. These show how water moves across the land, and areas can then be scored for risk by combining different risk factors or using machine learning, with India data from Indo ArcGIS Living Atlas.
5.How does India send flash flood alerts to the public?
India uses SACHET, an alert system run by NDMA, which has been used to send over 134 billion SMS alerts in more than 19 languages. Since May 2026, a Cell Broadcast System linked to SACHET can also send alerts to phones in a defined area within seconds.
Written by
Esri India Marketing
Next Article
Smarter Asset Inspection with ArcGIS API for Python
Read this article
