GIS in Mining: How Geospatial Tech Is Shaping India's Critical Minerals Push
GIS for critical mineral exploration uses Geographic Information System (GIS) technology to combine satellite imagery, geophysical surveys, and baseline geoscience data into a single spatial view, narrowing down where a critical mineral deposit is most likely to sit before a single drill turns. In India, where a national mission and a fresh round of mineral block auctions are now built directly around this challenge, that spatial narrowing has become a genuine data problem, not just a mapping exercise.
Introduction: Why India’s Critical Minerals Target Is Really a Data Problem
India’s push for critical minerals, such as lithium, graphite, rare earth elements, and other materials essential to clean energy and advanced technology, runs into a hard constraint before mining ever begins: knowing where to look. Exploration teams have to sift through satellite imagery, decades of geological survey records, and geophysical anomaly data to identify a handful of promising sites worth the cost of a drill program.
Sifting is fundamentally a spatial exercise, which is exactly where GIS earns its place in the exploration workflow, turning scattered layers of geoscience data into a single, ranked view of where the exploration budget should go first.
What Is GIS for Critical Mineral Exploration?
GIS for critical mineral exploration is the practice of layering satellite imagery, geophysical survey data, and baseline geological information within a spatial platform to identify and rank areas most likely to hold a mineral deposit. Rather than treating each data source as a separate report, GIS lets analysts stack them on the same map and see where multiple independent signals point to the same location.
This distinction matters at the pre-drilling stage, since a drill program is expensive and a poorly targeted one wastes exploration budget with low probability of a find. A ranked, evidence-based target reduces that risk before any physical work begins.
India’s Critical Minerals Architecture: The Ministry of Mines, GSI, and the National Critical Mineral Mission
India’s critical minerals push runs through a small number of institutions working at different scales. The Ministry of Mines sets policy and regulatory direction, the Geological Survey of India (GSI) carries out the exploration work on the ground, and the National Critical Mineral Mission (NCMM), approved by the Union Cabinet on 29 January 2025 with an outlay of ₹34,300 crore over seven years, ₹16,300 crore in government expenditure and ₹18,000 crore in expected investment from public sector undertakings, sets the overall target.
The regulatory foundation for this push dates to 17 August 2023, when the Mines and Minerals (Development and Regulation) Act, 1957 was amended to notify 24 minerals as critical and strategic under Part D of Schedule I, including lithium, graphite, rare earth elements, tungsten, vanadium, and titanium. This built on a broader 2023 list of 30 critical minerals identified by a Ministry of Mines expert committee and released on 24 July 2023, which fed directly into the narrower list that the MMDR Act amendment made legally actionable for auctions.
That legal foundation has translated into real auction activity. As of the Seventh Tranche, launched on 23 March 2026 and offering 19 additional blocks, the Ministry of Mines has auctioned 46 critical and strategic mineral blocks across six completed tranches. The National Critical Mineral Mission also proposes a dedicated Centre of Excellence on Critical Minerals to support this pipeline with focused research capacity.
How GIS Assembles the Exploration Data Stack: NGDR, Geophysics, and Imagery
Before any spectral analysis or targeting work begins, an exploration team needs a baseline layer of what’s already known about an area’s geology. The National Geoscience Data Repository (NGDR), maintained by the Ministry of Mines, serves as this authoritative baseline source, consolidating geological, geochemical, and geophysical data collected across decades of survey work into one accessible repository.
Ministry officials have also directed exploration agencies to consult NGDR before starting new work specifically to avoid duplicating projects already underway elsewhere, a coordination step managed through the Central Geological Programming Board process rather than a feature built into NGDR itself.
Once that baseline exists, geophysical survey data adds a second layer. Airborne magnetic and radiometric surveys, along with gravity surveys, detect subsurface density and mineral anomalies that aren’t visible from the surface at all, while geochemical stream sediment sampling adds a third, ground-truthed signal. Bringing these into a common spatial framework typically requires interpolation methods such as kriging or inverse distance weighting to convert scattered sample points into continuous surfaces that can be compared against other layers.
Satellite imagery supplies the fourth layer, and it’s where remote, hard-to-access terrain becomes analyzable without a field team physically walking every square kilometre. Together, NGDR, geophysics, and imagery form the raw data stack that spectral targeting, described next, actually works with.
The ArcGIS Image Workflow Behind Spectral Mineral Targeting
Reading alteration patterns from satellite bands
Mineral exploration increasingly relies on spectral indices, specific band combinations from satellite imagery that highlight iron oxide and hydroxyl-bearing minerals associated with hydrothermal alteration zones, the kind of surface signature that often surrounds a deeper mineral deposit. ArcGIS Image capabilities support this kind of multiband raster analysis at scale, letting analysts calculate these indices across an entire study area rather than a handful of manually inspected samples.
Building the analysis environment in ArcGIS Pro
ArcGIS Pro provides the desktop environment where this imagery analysis, geophysical layer processing, and NGDR data integration come together on one platform. Image analysis capabilities built for ArcGIS Pro extend this further with tools for feature extraction and change detection across multiple imagery dates, which matters for tracking how an alteration zone’s surface signature might shift or become clearer across different seasons and satellite passes.
Modelling terrain and hydrology alongside imagery
ArcGIS Spatial Analyst adds terrain and hydrologic modelling to the same environment, which matters because mineral deposits often relate to specific geomorphological settings, and understanding drainage patterns and terrain shape helps analysts interpret why an anomaly appears where it does rather than treating it as an isolated pixel value.
Scaling with a common reference layer
Indo ArcGIS Living Atlas gives exploration teams ready access to curated base imagery and reference layers for India, which removes the delay of separately sourcing and preparing foundational data every time analysis extends into a new exploration block.
From Layers to a Ranked Prospectivity Map: The Decision Output
Once the individual layers, geological baseline, geophysical anomalies, geochemical samples, and spectral alteration signatures, are assembled, the exploration workflow needs to combine them into a single decision-ready output. Multi-criteria prospectivity modelling does this by applying a weighted overlay, where each layer is scored and combined according to how strongly it correlates with known deposits, producing a single ranked map of candidate exploration areas.
This ranked output is the actual deliverable that changes how an exploration budget gets spent. Instead of allocating drill programs evenly across a broad area or relying on a single geologist’s judgment about where to look next, a weighted overlay output directs resources to the highest-probability ground first, which matters more as India’s own exploration data shows a shift toward deeper, less obvious targets.
That shift is already visible in the data. For Field Season 2026-27, GSI’s own exploration action plan shows a 46 percent increase in G3 stage exploration projects, the more advanced, resource-bearing stage of exploration rather than early reconnaissance, reflecting a strategic move toward concealed and deep-seated deposits that surface-level survey work alone cannot reliably locate.
How Indian Exploration Agencies Are Using Geospatial Data Today
At its 65th meeting held on 21 January 2026, the Central Geological Programming Board reviewed GSI’s annual exploration program for Field Season 2026-27, comprising 1,068 scientific projects in total. Of these, exploration-related work accounts for about 55 percent of the program, with 236 projects specifically formulated for critical mineral exploration. GSI has also formulated 37 projects in international border regions, of which 16 are mineral exploration projects spread across the Western, Eastern, Northern, and North-Eastern regions of the country.
The same program also allocates 144 projects to Natural Hazard Studies, Public Good Geoscience, and Fundamental Geoscience, alongside 58 dedicated Geoinformatics and Data Analysis projects focused on geospatial data generation, integration, and management using AI and machine learning approaches. This scale of activity, more than a thousand simultaneous scientific projects, is precisely the kind of workload that makes automated, GIS-based targeting a practical necessity rather than a convenience, since the ratio of projects to trained interpreters available to review each one keeps growing.
Organizations evaluating similar exploration data workflows can review how Mining and Natural Resources solutions from Esri India support this kind of geospatial data assembly and analysis work.
Challenges and the Road Ahead
Baseline geoscience coverage is uneven across states
Not every part of India has the same depth of historical survey data, and regions with sparse baseline coverage make prospectivity modelling less reliable simply because there’s less evidence to weigh in the first place. Closing this gap depends on new survey work reaching underexplored regions, not just better analysis of what already exists.
Legacy geological records remain undigitized in many areas
Decades of analogue geological records have not yet been converted into a format that a GIS platform can use directly, which means a meaningful share of exploration preparation time still goes into digitization rather than analysis. This is a foundational task that has to happen before any of the newer targeting workflows can draw on that data.
Coordinate system and schema mismatches slow data integration
Data collected by GSI and by individual state mining directorates doesn’t always share the same coordinate reference system or data schema, and reconciling these differences is a technical step that has to happen correctly before layers from different sources can be combined reliably.
Forest and tribal-rights overlays constrain access before geology does
In many promising exploration areas, forest clearance requirements and tribal land rights determine what ground is actually accessible long before geological potential becomes the limiting factor. A prospectivity map that ignores these overlays risks directing exploration attention toward areas that carry a land-access problem the geology alone can’t solve.
Every ranked exploration target represents a bet on where India’s mineral security will come from next. As the National Critical Mineral Mission’s seven-year outlay moves from policy commitment to auctioned blocks and field programs, the exploration data stack described here (baseline geology, geophysics, imagery, and the spatial analysis that ties them together) is what determines whether that bet lands on the right ground.
FAQs
1.What is GIS for critical mineral exploration?
GIS for critical mineral exploration layers satellite imagery, geophysical survey data, and baseline geological information within a spatial platform to identify and rank areas most likely to hold a mineral deposit. It replaces separate, hard-to-compare data reports with a single spatial view that highlights where multiple signals point to the same location.
2.What is the National Critical Mineral Mission and what are its exploration targets?
The National Critical Mineral Mission, approved on 29 January 2025 with a ₹34,300 crore outlay over seven years, aims to strengthen exploration, mining, and processing across India’s critical mineral value chain. It builds on GSI’s exploration pipeline, which includes 236 critical mineral projects planned for Field Season 2026-27 alone.
3.How does satellite imagery help identify mineral deposits?
Satellite imagery reveals spectral alteration patterns, particularly iron oxide and hydroxyl indices, that often surround hydrothermal alteration zones associated with deeper mineral deposits. Multiband raster analysis tools let analysts calculate these indices across large areas rather than relying on manual inspection of individual samples.
4.What is the National Geoscience Data Repository and what data does it hold?
The National Geoscience Data Repository is a Ministry of Mines platform that consolidates decades of geological, geochemical, and geophysical survey data into one authoritative baseline source. Exploration agencies are also encouraged to consult it before starting new projects to avoid duplicating work already underway.
5.What are the main challenges in applying GIS to critical mineral exploration in India?
The biggest challenges are uneven baseline geoscience coverage across states, legacy geological records that remain undigitized, and coordinate system or schema mismatches between GSI and state-level datasets. Forest clearance requirements and tribal land rights also often determine what ground is actually accessible before geological potential becomes the deciding factor.
Written by
Esri India Marketing
Next Article
Smarter Asset Inspection with ArcGIS API for Python
Read this article
