Change Detection Using Satellite Imagery: How India Is Tracking Urban Sprawl
Why Tracking Urban Sprawl Matters for India
India’s cities are growing faster than what maps can keep up with. Between 2011 and 2024, urban footprints in Bengaluru, Hyderabad, and Pune expanded by tens of square kilometres, often before official records caught the shift.
Change detection using satellite imagery is now the most reliable way to see this growth in near real-time. It lets planners, urban local bodies (ULBs), and policymakers track sprawl, encroachment, and unplanned expansion at the city scale, year after year.
According to UN DESA, India will add over 400 million urban residents by 2050. That pace is straining roads, water supply, drainage, and housing in nearly every major city. When growth happens outside the master plan, services lag, taxes go uncollected, and ecological zones shrink quietly.
Manual surveys cannot keep up with this scale. Satellite-based urban monitoring gives Indian cities a way to measure expansion every month or quarter, instead of waiting for the next census or land survey.
What Is Change Detection Using Satellite Imagery?
Change detection using satellite imagery is the process of comparing two or more satellite images of the same location, captured at different times, to identify and measure changes on the ground. It is widely used in remote sensing for city planning to track urban sprawl, deforestation, land use shifts, and infrastructure growth.
The core idea is simple. Pixels that look different between two image dates almost always mean something changed on the ground: a forest cleared, a road built, a wetland converted, a new colony added.
The technique works at the city level and at the individual plot level, depending on the resolution of the imagery. Indian agencies pair this with imagery and remote sensing capabilities in ArcGIS to scale the analysis across districts and states.
How Satellite Imagery Captures Urban Sprawl Over Time
Multi-temporal satellite imagery stacks images of the same area taken across months or years to reveal growth patterns. A built-up index applied to a 2014 and a 2024 Sentinel-2 image of Hyderabad, for example, will instantly show which farmlands turned into housing colonies.
Three image properties make this work:
Together, these properties let analysts run geospatial change analysis for a city across two decades at a stretch.
Key Techniques Used for Change Detection
Planners use a few well-established techniques, depending on the question they want to answer. Below are the main methods used for change detection in remote sensing.
1. Pixel-Based Change Detection
This method compares pixel values between two image dates. Simple band differencing, image ratioing, and index-based methods like NDBI (built-up index) and NDVI (vegetation index) all fall here. It is fast and works well for broad sprawl detection.
2. Object-Based Change Detection
Object-based methods first group pixels into meaningful shapes such as buildings, plots, or road segments. Changes are then measured between these objects across dates. This approach gives cleaner results for urban growth monitoring in dense Indian cities.
3. Time-Series Change Detection
Algorithms like CCDC (Continuous Change Detection and Classification) and LandTrendr analyse the full stack of available images, not just two dates. They are useful for catching slow, creeping sprawl that a simple before-and-after comparison would miss.
4. Deep Learning and GeoAI
Pretrained deep learning models classify land cover, extract building footprints, and flag changes automatically. These models, available through the Indo ArcGIS Living Atlas, scale change detection in remote sensing from a single city to an entire state.
ArcGIS Pro includes a dedicated Change Detection Wizard that wraps these techniques into a guided workflow, making them accessible to urban planners without a coding background.
India’s Urban Sprawl Story: Cities Under the Lens
Indian cities show some of the sharpest sprawl signals on the planet. Bengaluru’s built-up area has expanded sharply since 2000, eating into the lake network and the southern green belt, as documented in long-term remote sensing studies. Hyderabad’s growth along the ORR corridor is visible from space as a clear ring of new construction.
Tier-2 cities are catching up just as fast. Raipur, Bhubaneswar, Coimbatore, and Surat all show measurable expansion at the urban fringe. A multi-temporal Sentinel-2 stack reveals how peri-urban farmland is being absorbed faster than master plans can be revised.
Land use land cover change maps for these cities now feed directly into Smart Cities Mission dashboards, helping mayors and commissioners spot pressure points early. Most workflows combine Cartosat, Resourcesat, and RISAT from ISRO/NRSC with global missions like Landsat and Sentinel-2 for both detail and revisit frequency.
How Indian Agencies Are Using Change Detection Today
Several Indian state agencies already run change detection workflows on ArcGIS technology.
The Haryana Space Applications Centre (HARSAC) uses ArcGIS to monitor agricultural land conversion and crop area change, supporting state-level reforms. The Aryabhatta Geo-Informatics and Space Application Centre (AGiSAC) in Himachal Pradesh has deployed ArcGIS-based solutions for governance applications, including land and resource monitoring.
The Remote Sensing Applications Centre, Uttar Pradesh (RSAC-UP) uses ArcGIS for spatial analysis projects that include road network optimisation and land use studies. The National Mission for Clean Ganga (NMCG) runs the PRAYAG platform on ArcGIS to monitor changes across the Ganga basin in near real-time, supporting decisions on pollution control and infrastructure.
For city-scale deployments, Indo ArcGIS packages these capabilities into ready-to-use GIS solutions and India-specific datasets, helping agencies start change detection projects faster.
Benefits for Urban Planners, ULBs, and Policymakers
Change detection delivers practical, decision-grade information for everyone involved in city governance. Here are the most direct gains:
Together, these benefits shorten the gap between what happens on the ground and what shows up in city records.
Challenges and the Road Ahead with AI-Driven Change Detection
Change detection is not without friction. Cloud cover during the monsoon limits optical imagery, especially for cities in the Western Ghats and the northeast. Mixed pixels, where one Sentinel-2 pixel covers part building and part vegetation, can confuse simple methods.
GeoAI is closing these gaps quickly. Pretrained models for land cover classification and building footprint extraction, available through the Indo ArcGIS Living Atlas, now handle Indian terrain and architecture well. SAR satellites such as RISAT and Sentinel-1 add cloud-penetrating coverage for the monsoon months.
The next phase will combine satellite imagery, drone surveys, and IoT sensors into a single digital twin of each city. Indian cities that invest in this stack now will have a measurable head start on planning, climate response, and citizen services.
Get started with Esri India: Indian government agencies, smart cities, and planning bodies can adopt change detection workflows through Indo ArcGIS and ArcGIS Pro, with India-specific data layers and pretrained models built in.
FAQs
1. What is change detection using satellite imagery?
Change detection using satellite imagery compares images of the same location taken at different times to identify what has changed on the ground. In Indian cities, it is widely used to track urban sprawl, land use shifts, and unauthorised construction.
2. How does satellite imagery help track urban sprawl in India?
Satellites capture repeat views of every Indian city every few days. By comparing these images over months or years, planners can pinpoint exactly where new construction, road networks, or peri-urban expansion is happening.
3. Which satellites are used for change detection in Indian cities?
Most workflows combine ISRO satellites like Cartosat, Resourcesat, and RISAT with global missions such as Landsat and Sentinel-2. Bhuvan, run by NRSC, also provides ready-to-use Indian imagery layers.
4. What are the main techniques for satellite-based change detection?
The main techniques are pixel-based methods (NDBI, NDVI, image differencing), object-based methods, time-series approaches like CCDC and LandTrendr, and deep learning models for land cover and building footprint extraction.
5. Why is monitoring urban sprawl important for Indian cities?
Indian cities are growing faster than their master plans can be updated. Monitoring sprawl helps ULBs plan infrastructure, prevent encroachment, capture lost property tax revenue, and meet Smart Cities Mission and AMRUT 2.0 reporting targets.
Written by
Esri India Marketing
Next Article
Smarter Asset Inspection with ArcGIS API for Python
Read this article
